temp. gauge going up up up
Old Apr 21, 2008 | 05:47 PM
kahnvict850's Avatar
Default RE: temp. gauge going up up up
thanks desert for the indepth reply, i am going to get some 50/50 from auto zone right now, one thing i know for sure as for the fans, when i had the car running for a while then turned on the a/c popped to hood and both fans were on, so dunno, now both hoses are hot before they were not.
Old Apr 21, 2008 | 05:51 PM
deserthonda's Avatar
ORIGINAL: kahnvict850
you need to make sure that both fans work when engine gets warm WITHOUT putting the a/c on ..
Old Apr 21, 2008 | 05:55 PM
ok, how long do you thing it might take for a car to get warm enough for both fans to be on?? also is 1 gallon 50/50 antifreeze enought or do i need more??
Old Apr 21, 2008 | 06:02 PM
might take several minutes,, make sure to monitor the needle on the gauge,,
lower hose should begin to feel hot ( t-stat opening ) when needle is about or slightly above 1/4 at the temp gauge
Both fans should come on when needle is at around 1/2 \ at temp gauge
if needle is at 1/2 on the gauge and lower hose is NOT hot ,, t-stat is sticking closed , needs replacing ..
1 gallon mix 50-50 should do the job
chk this out..
https://www.hondaaccordforum.com/OVE...m_20999/tm.htm
Old Apr 21, 2008 | 06:32 PM
desert , a definate thank you to you for your help, i took the car for a short drive, came back home popped the hood, both fans on, top hose and bottom hose hot , turned car off and the passenger side fan stayed on for a short time then cut off, all sounds good???
Old Apr 21, 2008 | 06:44 PM
sir_nasty's Avatar
Sounds to me like you've got it! Since you had a hot upper hose at one point and a cold lower hose you may still have a sticky thermostat so if your issues come back then keep in mind that it may need replacing...
Old Apr 21, 2008 | 06:53 PM
  #17
thanks sir nasty, definatly keeping an eye out for the t-stat
Old Apr 21, 2008 | 10:06 PM
  #18
How about the collapsed radiator hose?
If the cap is OK, what about a clogged hose leading to the overflow reservoir?
Old Apr 22, 2008 | 06:37 AM
  #19
not sure if the cap was a problem, but i bought a new one, all seems fine as of right now.
pirulino23
Nov 10, 2010 06:18 PM
markinchico43
Jan 20, 2008 08:34 PM
raf105
Sep 28, 2007 02:55 PM
honker3
Dec 6, 2005 08:33 PM
fperezal
Sep 29, 2005 09:29 PM
