temp gauge pegged out
Old Jan 27, 2013 | 04:21 PM
BROCKINTN's Avatar
Angry temp gauge pegged out
I have a 1998 honda accord lx 2.3 and my gauge all of a sudden will peg out when you start the car up. The car is not over heating. I replaced the sender and the cluster and it still does it. I can disconnect the sender wire and the gauge will go down. I have the two clusters and know matter which one i put in it does it. Please help
Old Jan 27, 2013 | 07:18 PM
Strange - if it's OK with the wire disconnected, then it should be a bad sender.
I guess it's possible for your new sender to be bad right out of the box.
Try moving the disconnected wire around, pulling it this way & that. If that wire gets shorted to ground only in a certain position, that might help you located the problem.
pirulino23
Nov 10, 2010 06:18 PM
wietgr
Nov 12, 2007 05:41 PM
raf105
Sep 28, 2007 02:55 PM
frombozeman
Apr 1, 2007 01:23 AM
fperezal
Sep 29, 2005 09:29 PM
