Temperature Gauge reading WAY ABOVE hot
Old Sep 12, 2010 | 07:45 PM
I don't know about grounding a wire. In the past, the sender was just wired into the gauge, and if you grounded THAT wire the gauge would climb up to HOT. You had to stop before it got there, to avoid damaging the gauge.
But now, I think the gauge is driven by the ECU, it's not a simple stand-alone circuit. So I suspect shorting the sender wire(s) wouldn't damage the gauge.
Old Sep 12, 2010 | 08:56 PM
legazy's Avatar
Originally Posted by kris_loehr
Would grounding a wire for the temp gauge do that and what happened to the battery?
i dunno what happened to the battery when i tried to turn onthe car after i installed the ipod connector the battery was dead i came back later and it started i opened the hood and there was like this grainy white stuff on the batter similar to when a normal battery leaks. I didn't mess with the dash meters at all. My dads gonna replace the battery tmrw while im at school so hopefully that work?
sarhodes1984
Sep 19, 2012 04:39 PM
vikkyhonda
Feb 1, 2012 06:34 PM
jgresh110
Jun 26, 2011 09:41 PM
haccord93
Aug 10, 2009 08:48 AM
Karthigan
Nov 27, 2006 02:55 PM
