Temperature/pressure gauge on dashboard issues
Old Jun 14, 2015 | 03:14 PM
  #31
tashier's Avatar
Your sender resistance readings are higher than listed in the Honda manuals; however, since the resistance is higher, it should even be less likely to cause the temperature gauge to spike immediately with the key on.
Other people with 4th generation Accords have reported the resistance with the car warmed up at about 70 ohms. The resistance will be lower if the coolant temperature was hotter.
If your gauge is still spiking immediately with the key on, it may be due to a short in the wiring or the gauge is the issue.
With the car cool, plug back in the Red wire back into the sending unit. Go inside the car and measure the resistance at the instrument gauge's green 22P connector's Red wire at terminal number 5. Ignition switch position can be turn off when measuring the resistance.
Compare the resistance readings at the sending unit and inside the car. Are they relatively similar?
OK, I know it's been months LOL. But I got the heater core replaced and parts back on the car enough to run it again and take some readings. Right now the car is cold and resistance is reading 950 now where before it was reading in the 300's, both at the sensor and at the connector on the Instrument panel. Now I'm suspecting a bad sender if it going to have huge variations like that. What should correct readings be?
One book I found said 142 cold and 49-32 hot.
Old Jun 14, 2015 | 04:55 PM
  #32
I would say that unplugging the sensor and not having the needle move pretty much narrows down the problem to the sending unit. Replacing it will likely fix your problem.
Jcaleno
Apr 17, 2007 01:24 PM
vishawn
Mar 12, 2007 01:19 AM
mdubb99
Jan 30, 2007 07:54 PM
Karthigan
Nov 27, 2006 02:55 PM
mycargov6room
Jul 7, 2005 10:28 AM
