Temprature controls not illuminated
Old Dec 3, 2007 | 08:10 PM
coupe50
Default Temprature controls not illuminated
Hi,
I have a 2003 Accord coupe 4 cylandnone of my temprature control buttons light up when I turn on the lights also the CD player's LCD screen is not illuminated any time. Using a flash light I can see that the screen is working but it is not illuminated so youcannot see the status. I have checked all the fuses under the dash and under the hood, also checked the dimmer switch just in case. Everything else on the dash works even the green led lights on the temp controls lightup but the text on the controls does not light up.
I presume there is a common source of light for temp controls and the lcd screen, which is not working but I am not sure. Any help is greatly appreciated.
Thanks
coupe50
Accord Coupe 2003 2.4L
Old Dec 4, 2007 | 07:13 PM
HondatechAV6's Avatar
Default RE: Temprature controls not illuminated
there is a 7yr/100,000 mile warranty on the audio/climate control illumination. bring it to any dealer if your car is under 100,000 miles.
Old Dec 4, 2007 | 09:46 PM
coupe50
Thanx a bunch! I have 68K miles so this should be covered. I was really worried because this did not seem like something easy to fix.
Thanx
Old Dec 5, 2007 | 06:09 PM
it's fairly easy, we tear apart the radio and replace the circuit board inside it. before the warranty came out ppl online tore it apart and found out a resistor goes bad(i think)causing no illumination.
Frugalhondaguy
May 5, 2015 11:22 AM
Kahana70
Jul 17, 2012 09:15 PM
55chevrolet
Feb 26, 2012 12:11 PM
Drpepper
Jun 7, 2007 12:34 PM
taffia
Jan 30, 2007 02:47 PM
