Is there any way to stop wind noise coming from window?
Old Jan 6, 2009 | 12:52 PM
jose310's Avatar
Default Is there any way to stop wind noise coming from window?
is there anything i can adjjust in the car?
Old Jan 6, 2009 | 01:00 PM
finch13's Avatar
Default RE: Is there any way to stop wind noise coming from window?
which windows? If theyre power side windows... they may be something stuck in the track or they just dont have the power anymore to roll them all the way up...
Old Jan 6, 2009 | 01:09 PM
jose310's Avatar
power windows...and they go up and down quick, how do i clean the tracks?
Old Jan 6, 2009 | 02:12 PM
finch13's Avatar
If they go up and down quick, the tracks might not be the problem. Can you feel wind coming through the top of the window or is it just loud?
Old Jan 6, 2009 | 03:19 PM
hondadude's Avatar
There are minor adjustments on the window regulator under the door panel to change the 'tilt' of the window.
Iwould first use some painters masking tape to make sure of where the noise is coming from.
Put a wide strip of tape along the top edge of the window and test drive. See if the noise goes away.
Old Jan 6, 2009 | 05:02 PM
jose310's Avatar
Its loud on the freeway, I took out the black clip on the window, and straighten out the black rubber piece that goes around the window, im going to see if it helped wen i go on the freeway in a bit.
skipisley
Sep 17, 2012 12:51 PM
WindPhoenix
Aug 24, 2012 10:36 PM
94ex915
May 29, 2012 03:36 PM
cyberfriend
Jan 22, 2009 11:24 AM
badxdawgx818
Sep 4, 2007 03:36 PM
