Is there any way to track/trace a junkyard engine/motor?
Old Jan 22, 2009 | 02:12 AM
cyberfriend
Default Is there any way to track/trace a junkyard engine/motor?
I had a junkyard engine in my car until the engine blew recently and i have to replace it. 2 shops have independently verified that the engine is in fact a junkyard engine, due to the yellow digits scrawled on it that would identify it as such.
will i be able to track where that engine came from? or if i'm not "privvy" to that information because i'm joe-nobody, would a government group (ie: DMV etc) be able to do that?
Old Jan 22, 2009 | 07:43 AM
Default RE: Is there any way to track/trace a junkyard engine/motor?
Why would you want to track where an engine is from..Im curious too that question...
Old Jan 22, 2009 | 08:46 AM
cjdm98's Avatar
A junkyard engine is a junkyard engine.just that. No way are you going to be able to find out where it came from unless the seller has the knowledge.
Old Jan 22, 2009 | 09:08 AM
Are you asking so you can buy another junkyard engine that somehow matches?
Look at the front of the block, alongside where the tranny bolts up. Theres a flat space with type & serial # stamped in, for examplelike this:
F22B1
1234567
The first line is the type of engine.
The first digit in the 2nd line indicates the model-year of the engine.
We dont really need the remaining digits of the serial #.
Old Jan 22, 2009 | 10:01 AM
If it still has the VIN on it you could do a carfax and see the history of the car it came out of.
Old Jan 22, 2009 | 11:24 AM
VIN tag was only required beginning about 1996 in USA. Before that, or elsewhere in the world, it may not have ever had a VIN tag.
skyfire322
Jan 8, 2014 01:55 PM
94ex915
May 29, 2012 03:36 PM
jose310
Jan 6, 2009 05:02 PM
faosh
Jan 17, 2008 01:13 PM
