Thermostat Replacement
Old Oct 29, 2011 | 06:09 PM
rwyatt80's Avatar
Default Thermostat Replacement
I have been looking through the site and have been unable to locate a DIY on thermostat replacement on a 1996 honda accord lx.
Is it possible I have overlooked it? I am notorious for that
any help on how it is replaced is greatly appreciated!!
Old Oct 29, 2011 | 06:25 PM
4cyl-being an lx I can assume so? I can hit the highlights.....
1) drian the coolant, or not. If not be prepared
2) remove the air intake for room
3) remove the t-stat housing (lower hose), depending on step one...there may or may not be a mess of fluid
4) Note direction of old t-stat, install new...pin up.install housing
5) Open bleeder, turn heat to max, refill rad....close bleeder when full
6) run car until cooling fans cycle at least once-keep an eye on the temp gauge-if it starts to over heat...shut it off
Old Oct 29, 2011 | 06:31 PM
Follow poorman212's instructions. See # 8 and #12 in this thread to give you some visual, many of the other steps do not apply since you would not be removing the radiator, other than maybe draining the coolant from the radiator.
"http://honda-tech.com/showthread.php?t=2576131"
Old Nov 3, 2011 | 06:53 AM
rwyatt80's Avatar
Thanks guys!! I was able to get the thermostat changed! I appreciate it!!
Hondamatic
Dec 31, 2005 07:29 PM
LaminatedKitten
Dec 21, 2005 11:23 PM
MaxPower
Oct 9, 2005 05:21 PM
MaxPower
Aug 16, 2005 05:42 PM
94accordprobs
Apr 29, 2005 12:11 AM
