Think I have a problem
Old May 17, 2010 | 04:00 PM
Machman 69-04's Avatar
Default Think I have a problem
Tried to search this but can't seem to find the answer I'm looking for. I have a 2007 accord V6 AT. At low rpm (up to around 2000) I get a slight vibration that I can feel in the steering wheel and gas pedal. Does not matter what gear the car is in, I get the same very light vibration. Car has 56000 miles and seems to run good other then that. Had the tranny fluid changed thinking that might help. Now I'm thinking egr valve......thoughts?
Old May 17, 2010 | 04:42 PM
I would have thought an EGR problem would cause misfiring, stumbling & sputtering. When you say "vibration" it sounds more uniform.
Old May 17, 2010 | 04:57 PM
Its almost like driving a manual car....if you tried to pass someone without upshifting and just floor it you would get that little vibration feeling as well. Basically its happening when I'm driving and I give it a little gas but not enough to make the car want to upshift. Not sure how to describe it any better.
Old May 17, 2010 | 07:36 PM
Try to test-drive a 2007 V-6 at a dealer. As a long-time 4-cyl driver, that sounds normal to me.
Old May 17, 2010 | 08:25 PM
Will do, I'm kind of **** about everything on my cars so maybe I'm being over skeptical. Thanks
Old May 18, 2010 | 06:25 AM
V-6 is supposed to be smoother than a 4-cyl, but maybe they just program the trans to shift at lower RPM.
RachelC87
Jun 17, 2013 12:52 PM
remacts
Jun 8, 2013 01:33 PM
Tek310
Jul 2, 2011 07:52 AM
salvatore militello
Feb 9, 2010 08:44 PM
YeuEmMaiMai
Aug 3, 2006 03:02 AM
