Ticking noise
Old Mar 13, 2007 | 03:29 AM
walker
Default Ticking noise
Hello all,
I hope you guys can help me. I'm an owner of a 2002 honda accord ex v6 and lately I have been hearing this ticking noise on the right side of my car when I accelerate. As I accelerate faster, the ticking noise also ticks faster. You can hear this noise outside of the car as I am driving. When I cold start the car in the morning, the ticking noise is loud, but as the car warms up, it becomes softer, but still there. I don't know where it is coming from and I was hoping someone may have also experienced this. If you have any suggestion on what is causing this, I would really appreciated.
Thanks!
Old Mar 13, 2007 | 04:17 AM
deserthonda's Avatar
Default RE: Ticking noise
how often do you change the oil and filter ?? noise coming from engine area ? is noise on while engine is at idle ? could be sticking Hydraulic lifters ..
Old Mar 14, 2007 | 04:43 PM
walker
Thanks for the reply. I actually had my oil and filter changed 4 months ago and have driven about 1300 miles since. The noise sounds like it is coming from the back or near the gas pump area. The noise does not come on while the car is idle, but only when I start accelerating. The car appears to be driving fine and I'm hoping it is not something serious.
Old Mar 14, 2007 | 07:03 PM
One of the solenoid valves in the EVAP system??? Those live under the car, roughly underneath the left-rear seat but sometimes noise travels funny.
Old Mar 14, 2007 | 07:09 PM
sir_nasty's Avatar
Is it coming from the rear of the car? if so a common issue is a nail/tack/rock stuck in the tread.... drive forward slowly and have someone inspect the tire all around while you're moving to make sure nothing is stuck in there, if you know specifically which side it's from then you could also jack up that side and remove the tire, if you can't find anything wrong with the tire then throw the spare on and drive around, if the noise is still there I'd suspect a wheel bearing, try rotating the tire by hand when it's jacked up and see if the noise persists....
mortuzahasan
Sep 30, 2014 06:43 AM
camman
Jan 12, 2014 07:39 PM
mattk79
Mar 8, 2012 12:20 AM
Custnam
Oct 21, 2008 10:31 AM
weekendwrench
Oct 18, 2008 07:16 PM
