timing & balance shaft belts
Old Jan 29, 2007 | 06:41 PM
quietgiant's Avatar
Default timing & balance shaft belts
On my 1999 Accord DX 4cyl vtec.
Does this engine have both timing and balance shaft belts and tensioners or, just the one timing belt and tensioner?
Also, while ordering parts, I came across the term"interference engine application", what does this mean?
Sorry if these are simplistic questions.
QuietGiant
Old Jan 29, 2007 | 08:35 PM
tech75
Default RE: timing & balance shaft belts
interference engine means that valves and pistons will hit each other if engine is not set up right. u need a t-belt, water pump, balancer belt, and all seals , u should change them while ur in there to prevent oil leaks. u can reuse the tensioner.
Old Jan 29, 2007 | 09:26 PM
quietgiant's Avatar
The car has 67,000 miles. I have both tensioners in hand (but, I can return them). I wasn't sure if this enginehad two tensioners and belts. Your answer infers yes, there are two (Timing and Balancer belts and two tensioners). Next question... Can I get the crank pully bolt off with an air impact gun or do I need a special tool and a long breaker bar.
Old Jan 29, 2007 | 09:29 PM
sir_nasty's Avatar
you can use an air impact gun if it's heavy duty enough, I believe it's going to be torqued around 200 ft/lbs so you need to have an impact gun rated at around 250 ft/lbs of torque max and then just let it "bang away" at it for about 30 seconds or so and it should come loose, if you've got the tensioners and they aren't that expensive then just replace them it won't hurt you and it ads peace of mind
tech75
sometimes they come off with the air gun there is a special pulley tool. good luck.
Old Jan 29, 2007 | 09:52 PM
quietgiant's Avatar
Thanks!
Old Jan 30, 2007 | 01:37 AM
deserthonda's Avatar
here you go Giant ,, hope this helps
http://members.troublecodes.net/hond...ccordTbelt.jpg
wolfverine37
Nov 29, 2012 03:04 PM
mugenpaolo
Apr 13, 2009 09:34 PM
rschmitt2
Jan 6, 2007 08:31 PM
golpha
Nov 25, 2006 12:06 AM
accord4sroy
Apr 22, 2006 02:40 PM
