timing belt
Old Sep 13, 2008 | 01:44 PM
RJLhonda
Default timing belt
Dose any one know of a good PDF file I can look up on line and find out how to change my timing belt thank you
Old Sep 13, 2008 | 02:42 PM
Default RE: timing belt
What is the year/model of your accord?
Old Sep 13, 2008 | 03:32 PM
hondadude's Avatar
This link might help you;
http://img293.imageshack.us/my.php?i...rdtbeltki1.jpg
Old Sep 13, 2008 | 07:07 PM
RJLhonda
It's a 1997 honda 2.2 vtec
Old Sep 14, 2008 | 12:38 PM
Hondadude or anyone.
This procedure (Honda factory procedure) requires separate steps to install timing belt and balance shaft belt, w/ installation/removal of lower timing belt cover and crankshaft pulley between. This is tedious and not clear why this is necessary? I have always installed both belts, installed crankshaft pulley w/o TB cover, perform tensioning procedure, check alignments, and then remove crankshaft pulley, install lower TB cover, final installation of crankshaft pulley, and a final tensioning procedure sincetensioner lock nut must be removed to allow TB lower cover installation.
Regards
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
