Timing belt
Old Oct 20, 2019 | 10:26 PM
Vantheman's Avatar
Default Timing belt
New here. I got a 96 accord ex 2.2 vtec. Im wanting to change the crankshaft pos. Sensor but i see that i have to take the timing belt loose. Its dried out so I'd like to replace it simce theres 236000 on the car and previous owner knows nothing about if it was ever replaced. Just looking for some helpful tips hints and or help in doing so. I used to be a general service tech but never messed with timing belts so this will be my first. Thanks in advance!
Old Oct 21, 2019 | 02:43 PM
The Toecutter's Avatar
I'd get the timing belt water pump kit from Rock Auto. It'll have everything you need, along with a very good set of instructions. Make sure your car has either VTEC, or is a non-VTEC engine, as the belts are different. You'll need to rent a Honda crank pulley tool to hold it in place (you'd need it if you were just changing the sensors too) while you remove the crank pulley bolt. It's supposed to be torqued up to 150 ftlbs, but someone may have added some loctite to the threads. You'll also want to get the balance shaft seal retainer kit (5 bucks) and a valve cover gasket set, since you'll have the cover off. I'd probably do a set of plugs while I'm in there, unless you know the mileage since they were last done.
I hope this helps.
Paddy
Oct 13, 2019 01:29 PM
rakeshb10
Jun 23, 2010 01:35 PM
indy49
Dec 13, 2008 09:58 PM
southpark0000001
Oct 1, 2007 10:03 AM
Tony1M
Apr 1, 2007 05:42 PM
