Timing belt changed... now little noise?
Old Aug 12, 2011 | 04:15 PM
Protna's Avatar
Default Timing belt changed... now little noise?
Hey guys so I just changed my Moms timing belt on her 2004 Accord with the 3.0 V6. During the replacement I probably should have removed the automatic belt tensioner but I didnt. I took the lower timing cover off which is right behind the tensioner and when reinstalling it a piece of it broken off and the timing belt is exposed in one small corner. After putting everything back together there was a small rattling noise comming from the engine. I could only hear it when in park while the engine is running and standing outside the car. When im in the car I cant even hear it. Im curious if the noise is due the the fact that a small part of the belt is exposed? Everything has been running fine for the last 2 weeks so I would assume everything else was ok but maybe im wrong? Should I be concerned?
Any help greatly appreciated thanks.
Old Aug 12, 2011 | 06:10 PM
Hard to believe you could do the timing belt job w/o removing the serpentine belt tensioner, if that's what you mean.
The timing belt cover should be replaced. W/o the cover the belt will be exposed to dirt and grease. This could result in early failure.
Old Aug 14, 2011 | 08:51 AM
hobieslug45's Avatar
you could try putting duct tape on the hole to see if the noise goes away, but you should change the cover . the only time I was able to take a belt off with out removing the tensioner was when the tensioner was bad. I was amazed that it didn't jump a tooth especially the way the driver of this car drove . I seen him pass up a car who was passing another car. when you replace the bottom cover look things over carefully. get into an interference engine frame of mind.
Old Aug 14, 2011 | 12:13 PM
Protna's Avatar
To clarify im talking about the serpentine belt automatic tensioner, not the timing belt tensioner. I did remove the timing belt tensioner and used a coat hanger to put the pin back in place. Then pull the hanger our when time to release tension.
Old Aug 14, 2011 | 01:41 PM
listen for noise coming from the serpentine belt tensioner I have a stethoscope but a long screw driver will work BE VERY CAREFUL. look to see if it is vibrating . and when you pull back on the tension is it smooth.
Old Aug 14, 2011 | 02:58 PM
When I changed water pump & timing belt on my Acura MDX w/ 3.5L V6 (similar to yours), I ran the engine briefly w/ timing belt cover off (crankshaft pulley installed) to make sure all was working correctly. Only noise was a slight whirring sound. I replaced both tensioner and idler bearings.
I know how you hate to go back in to this job, but the consequences of faulty part or leaving TB exposed are too great IMO.
93Accord2.2
Nov 6, 2013 11:53 PM
dis360
Sep 12, 2013 04:08 PM
Accord01gt
Jan 8, 2012 07:40 PM
toddyfresh
Jan 19, 2009 09:41 PM
jrcastro
Mar 8, 2008 10:33 PM
