timing cover bolt
Old Apr 5, 2011 | 02:59 PM
wunderbra's Avatar
Default timing cover bolt
anyone have any tricks for that little timing belt cover bolt on the upper cover towards the rear? It is a major pain.
Old Apr 5, 2011 | 03:40 PM
Its been a while since I pulled the upper TB cover, so my memory is foggy.
I remember having to try several socket/ratchet combos until I could fit it in there on one of the TB cover bolts. I may have put the socket on the bolt, then pushed the ratchet in?
Old Apr 5, 2011 | 06:55 PM
Use a 1/4" drive ratchet and 10mm socket. This makes it easier, but still a challenge. It's in a difficult position,... but you knew that already.
Old Apr 5, 2011 | 07:23 PM
wunderbra's Avatar
with such little room to move a rachet, I tried an air ratchet. Only the power steering hose was in the way kinda. I got the ratchet and socket on the bolt head, but the lever ( trigger ) on the air ratched was fully squeezed 'on' by the PS hose wedged against it.
So, I just put the air on the ratchet then popped it off again real quick to simulate using the ratchet trigger.
Worked good!
john_pyro
Aug 4, 2019 05:06 PM
theDex
Oct 14, 2012 10:49 AM
Jet sitter
Apr 7, 2012 07:29 PM
johnjokela
Mar 30, 2008 09:11 PM
troy331
Sep 22, 2007 06:50 PM
