timing issues
I just replaced my timing belts on my 92 accord dx it ran fine before i started the job but when i took off the lower timing cover i noticed the secondary balancer/oilpump belt was broke i replaced the belts and water pump and put it all back together and it will start and run but wont rev past 3500 rpm, what could be my issue? PLEASE HELP I AM DESPERATE THIS IS MY ONLY CAR
Have you checked alignment between crankshaft and camshaft is correct?
Is Check Engine Light (CEL) on? If yes, get the code/s and post them. Check whether CEL stays on w/o blinking when service check connector is shorted to look for codes.
Suggest resetting the ECU by pulling BackUp fuse in underhood fuse box for 20 secs.
i replaced the timing and balancer belts saturday the car started and ran but wouldnt rev past 3500 rpm, checked the timing and was off re-timed it and it is exact to the mark but is doing the same thing please help i really need this car
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
GOT BOOST
Nov 2, 2009 08:32 AM
