timing issues
Old Jul 6, 2014 | 06:56 PM
Chance Avery's Avatar
Question timing issues
I just replaced my timing belts on my 92 accord dx it ran fine before i started the job but when i took off the lower timing cover i noticed the secondary balancer/oilpump belt was broke i replaced the belts and water pump and put it all back together and it will start and run but wont rev past 3500 rpm, what could be my issue? PLEASE HELP I AM DESPERATE THIS IS MY ONLY CAR
Old Jul 6, 2014 | 07:35 PM
Have you checked alignment between crankshaft and camshaft is correct?
Is Check Engine Light (CEL) on? If yes, get the code/s and post them. Check whether CEL stays on w/o blinking when service check connector is shorted to look for codes.
Suggest resetting the ECU by pulling BackUp fuse in underhood fuse box for 20 secs.
Old Jul 6, 2014 | 07:59 PM
Also, check that the ECU ground bolt on the thermostat housing is tight.
Old Jul 7, 2014 | 09:56 AM
Question need help bad
i replaced the timing and balancer belts on my 92 accord yesterday checked the timing 3 times and it will not rev past 3500 rpm, what could be the issue please i need help for this is my only car
Old Jul 7, 2014 | 10:08 AM
Default 92 accord wont rev past 3500 rpm
i replaced the timing and balancer belts saturday the car started and ran but wouldnt rev past 3500 rpm, checked the timing and was off re-timed it and it is exact to the mark but is doing the same thing please help i really need this car
Old Jul 7, 2014 | 10:18 AM
cel stays on constant, im going to try pulling the fuse i will let you know if it works oh and it doesnt flash any codes just stays on
Old Jul 7, 2014 | 11:48 AM
Jetmoto120's Avatar
Go here these guys are specific to our cars Brother F22a1 timing - CB7Tuner Forums
Old Jul 7, 2014 | 07:37 PM
Did you short the service connector to get the engine codes?
frankenstein69
Dec 28, 2014 12:36 AM
Ineedhelp
Jan 22, 2012 07:29 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
troy
Oct 4, 2006 12:42 PM
