Timing, water pump
Old Mar 18, 2015 | 07:18 PM
westm's Avatar
Default Timing, water pump
Forgot to put bolt in to hold back cam balancer what do I do, shaft rotated already.
Help please! , 99 ex sedan
Old Mar 19, 2015 | 05:16 AM
jkowtko's Avatar
Almost A Senior Member
Don't you have to pull the belts back off and re-position the balancer shaft?
Old Mar 19, 2015 | 06:18 AM
westm's Avatar
Is there a mark on back balancer to line up, or just rotate until it locks in place?
Old Mar 19, 2015 | 06:25 AM
Turtlehead's Avatar
There should be a service port bolt on the back of the block which you remove and can insert a #2 screw driver and rotate the balancer gear box until the screwdriver slides in, then check the balancer shaft mark, and be sure the timing marks are on. Do it while the engine is on TDC for the the number one cylinder. Ensure all bolts tight, remove screwdriver and reinstall service bolt. Service bolt should have a 12mm head, FYI.
kimh
Dec 13, 2006 06:07 PM
Island Accord
Dec 9, 2006 09:30 AM
kimh
Oct 30, 2006 07:11 PM
ckebottle
Oct 26, 2006 04:00 AM
emaxxman
Feb 21, 2006 09:15 PM
