Timing, water pump
Old Apr 2, 2015 | 06:11 AM
westm's Avatar
Default Timing, water pump
Water shooting out of radiator when engine spins, with cap off. Cap on leaks other places, builds up a lot of pressure. New timing kit and water pump.
Anyone with idea what will cause this, help please. 99 ex sedan
Old Apr 2, 2015 | 06:55 AM
V-6 or 4-cyl?
If it's really spitting out of there hard, it might be a failed headgasket. Combustion gases under pressure blowing into the coolant passageways displacing the coolant.
It's normal to see some movement in the coolant right under the radiator cap, when the engine is running. But that's not spitting & shooting out.
Old Apr 4, 2015 | 03:00 PM
Turtlehead's Avatar
Agree. Sometimes with the cap on you can check the reservoir for air being pumped in. If so then is almost always a head gasket.
kimh
Dec 13, 2006 06:07 PM
Island Accord
Dec 9, 2006 09:30 AM
kimh
Oct 30, 2006 07:11 PM
ckebottle
Oct 26, 2006 04:00 AM
emaxxman
Feb 21, 2006 09:15 PM
