Tire inflation
Old Mar 23, 2012 | 10:36 AM
Jet sitter's Avatar
Default Tire inflation
What do you guys run for tire pressure? I usually run 32psi all around, but I'm thinking about going to 35psi. I don't know what kind increase in gas mileage I will see, I currently get 29MPG combined. Yesterday, was the most costly fill up of my life, $51.92. The guy on the other side of the pump put $100. worth of diesel in his truck and he said that didn't fill it. Looking for fuel savings ideas.
Old Mar 23, 2012 | 11:02 AM
kyle102565's Avatar
32 psi is optimum regardless of max tire pressure stated on your tire.
i see cupped tires constantly on overinflatted tires.
ask a tire company, they will tell you 32
if you have a 4 wheel drive truck with mudders on it go for 60 psi
apples and oranges
Old Mar 23, 2012 | 12:45 PM
EXV6NIGHTHAWK's Avatar
Over inflated tires will wear quicker in the center of the tread, and give you a rougher ride. If wearing the tires faster, and a rougher ride is worth a couple miles per gallon go for it. 35psi is not bad really, but I wouldn't go any higher than that. I will usually inflate the tires to 33-34psi, to allow for the eventual loss of air as time goes by. That way it will be a longer period of time before the pressure is down to 30psi, and I have to add more air again.
Old Mar 23, 2012 | 07:38 PM
skramer's Avatar
When I buy tires, the max pressure is usually 44psi. I usually run 40psi. I never get cupped tires from running this way. The tire manufacturer says its fine up to 44psi. Why would it produce cupping at a pressure less than that? Mine never have. I usually get 40-60k miles out of run of the mill tires.
Old Mar 23, 2012 | 08:29 PM
UhOh's Avatar
my front pressure, too, and I'm sticking to it. probably 32 rear
Old Mar 24, 2012 | 01:59 PM
kyle102565's Avatar
all depends on the quality of tire you have. cheap tires tend to feather and wear terribly. i see it daily.
i raced speedway motorcycles for years and we'd run 12 psi on the rear tire (for traction), 32 up front.
i raced with a 60 year old veteran who also worked for Goodyear as an engineer. he ran 32 psi in his rear tire and smoked division 2, im tellin you ***** OUT!
after smokin my *** i became friends with him and we got on the tire pressure chat, he told me this, " countless hours go into tire manufacturing, these guys have Masters degrees in rubber, optimum tire pressure is 32 psi regardless of make or application"
i still ran 12 on the race bike, but i run 32 on the street.
i have new 17" Falkens on my Accord, they are at 32.
max psi on the tire doesnt mean you go there
JTracy
Aug 23, 2010 02:11 PM
Stoenr
Mar 29, 2008 09:23 PM
RTexasF
Jun 13, 2007 07:03 PM
DDTG_ACCORD
Apr 29, 2005 05:23 PM
remington870_20ga
Apr 7, 2005 05:22 PM
