tire rotation question
Old Jul 26, 2013 | 04:28 PM
sona1111's Avatar
Default tire rotation question
Hello, I have tried to keep my tires at the recommended pressure of 44 psi for the two in front and 35 for the two in back. I recently thought of maint I had not done yet: tire rotation. Most guides I found online had put most precedence in the rotation of the front tires to the back and vice-versa, but is this supposed to be done if the tires are of different pressures?
thanks.
Old Jul 26, 2013 | 05:14 PM
Honda's recommended tire pressure for the DX trim for normal driving is 32 psi for front and rear, as shown in the owner's manual and should be on the door jamb sticker.
Honda only recommends different front and rear tire pressures for V6 trim levels in that generation Accords.
If you're going by some other recommended tire pressures, then when you rotate them, then just change the tire pressures.
You can also get a tire depth gauge to compare the thread left to help determine when to rotate tires. Generally, the fronts will wear faster.
Old Jul 26, 2013 | 07:57 PM
sona1111's Avatar
thanks for the reply. I actually got the pressures from the sidewall of the tires themselves, so I guess the previous owner has put on some weird combination with the front tires being slightly bigger then the rear ones. (I have notices no problems related to this, however.) I guess I will just wait until I can buy a new set...
Old Jul 27, 2013 | 07:37 AM
Redbull already posted the OE tire pressure.
I think what you are seeing on the tire is the MAX psi for the tire. I would reduce the pressure to the OE tire pressure.
Old Jul 27, 2013 | 01:44 PM
Lightbulb Hi Members
I 2nd this post from RedBull1..correct tire pressure 32 psi..
Old Jul 28, 2013 | 12:22 PM
sona1111's Avatar
This is a little confusing for a newbie. It seems to me like the recommended pressure for the tires from the tire manufacturer would have more merit then the recommendation from the car manufacturer. The previous owner has seemingly put on two different types of tires with maximum pressures of 35 and 44. To me, logically it would seem that If i lower both of these to 32, one would be more "flat" then the other, if you get my meaning. Can anyone explain why this assumption is wrong?
Old Jul 28, 2013 | 01:03 PM
That is the tire manufacturer’s Max pressure rating, not the recommended tire pressure rating for your specific car. Generally, tires are made for and can be used on various and different makes of cars, which may have different weight, suspension, etc. There is no one recommended tire pressure that would be the same as every car makers’ recommended tire pressure for their specific car.
If you used the same tire inflation pressure on different cars and makes, each car will have different ride and handling qualities, roll resistance, etc. due to the weight difference, suspension design, etc. The car manufacturer’s recommended tire pressures are what they have determined to better suit the vehicle and driving conditions. Even Honda has different recommended tire inflation pressures for normal driving vs. high speed driving.
http://www.tirerack.com/tires/tirete....jsp?techid=33
http://www.tirerack.com/tires/tirete....jsp?techid=21
Assuming the two different brands of tires on your car are the same size and correct for your car, adjusting the tire pressure to Honda's recommended tire pressure may make the front tires look lower than the rear (due to weight of the engine on the front). However, the visual appearance of the tires will not have a detrimental effect.
Derekhhh
Oct 13, 2013 03:14 PM
Pajamarama
Jul 12, 2012 11:18 PM
ZionsWrath
Jun 13, 2010 11:14 AM
HondaAficionado
Sep 22, 2009 06:53 PM
mpc8240
Sep 26, 2007 08:41 PM
