Floor jack, Accord and tire rotation: How not to maim yourself?
Old Sep 21, 2009 | 12:02 AM
HondaAficionado's Avatar
Default Floor jack, Accord and tire rotation: How not to maim yourself?
So, can one just use a floor jack to lift one side of the car in order to swap the tires around? Or do you have to lift the front end, put jack stands, and then do the same to the rear? That seems like a lo of work, though.
Seems like it would be lots easier to lift one side and go to work that way.
What do you guys do?
Old Sep 21, 2009 | 12:57 AM
You need to get all 4 wheels off the ground so you can rotate and criss cross the tires from side to side and fronts to rears...
Old Sep 21, 2009 | 08:06 AM
I lift one corner, put on the spare, then move to the next corner & go around like that.
Don't go under the car with only a jack. Be careful & stay out from underneath when removing a wheel. If you have to reach underneath the car, use stands.
Old Sep 22, 2009 | 01:15 PM
dfaulkner's Avatar
put the whole car up on jackstands
Old Sep 22, 2009 | 06:53 PM
hondadude's Avatar
kick the lift arms under the lift points, walk over and push the button on the lift, raise it up chest high.
If man was meant to crawl around on the floor his back legs would bend like a dogs.
ROFLMAO I really crack me up !!
mtill58513
Mar 1, 2013 02:56 PM
letsclique
Dec 28, 2012 05:39 PM
Reggi's-accord
Dec 3, 2012 02:23 PM
PinkFloridaFlamingos
Dec 10, 2011 07:37 PM
ZionsWrath
Jun 13, 2010 11:14 AM
