totally need electrical help
I have a 93 accord that recently gave me some electrical problems.When i turned on the head lights it was on but the tail lights and dashboard light do not light up.I replaced the head light switch and checked all the fuses but still no lights.is there any body out there with a similar problem or solution? please help!
Are side marker lights, front parking lights, and license plate lights off also?
If yes, suspect the combination light switch on the column or fuse 32 (underhood fuse box).
Check red/blk wire out of steering column for voltage. If nothing a new combination switch is necessary.
Hi New Member
Please watch where you post things..
Jeffrimerman
03-19-2010 07:11 AM
Buktheng
01-05-2008 05:40 PM
