TPS for 1999 Accord EX 4cly
Old Mar 20, 2012 | 08:09 AM
Jennifer's Avatar
Default TPS for 1999 Accord EX 4cly
I have a 1999 Honda Accord EX 4cyl manual transmission and the throttle position sensor needs to be replaced. I know that the sensor is part of the Throttle Body. I was hoping to be able to just replace the sensor and I am having trouble locating just the sensor for my make and year. Does anyone know where I can buy a new one? Can I use one from another model year??
Old Mar 20, 2012 | 08:18 AM
Honda doesn't sell them because they don't think people should be able to replace them themselves. There also are special bolts holding it on that you will need to cut a slot in then use a screw driver to take off.
Also you will need a volt meter to set it, as it has to be very precise.
A search of ebay should find you one to replace it with though, I think basically all 90s Hondas used the same TPS but don't quote me on that.
Old Mar 20, 2012 | 10:13 AM
Dorman makes a TPS for your year Accord
"http://www.partsgeek.com/catalog/1999/honda/accord/fuel_injection/throttle_position_sensor.html"
Here is a link on how to remove the two shear bolts with a center punch and hammer (it is actually very easy and fast to do, probably less than a minute for each shear bolt).
Throttle Position Sensor - Honda-Tech
Old Mar 20, 2012 | 10:17 AM
Earlier Accords use a different TPS than the 1999 Accord, other aftermarket companies like Blox and Omni make it for those years.
Old Mar 20, 2012 | 11:16 AM
Jennifer's Avatar
Thank you all very much!!! I will check out the links and let you all know how it goes.
Old Mar 26, 2012 | 03:57 AM
Jennifer's Avatar
Got the part and it fit ;}. Thanks again
Torino
May 24, 2011 12:37 PM
mrbostn
May 18, 2011 09:53 PM
rmitchell4931
Jul 13, 2010 03:38 PM
cecoen
Sep 3, 2009 03:58 PM
Zambo
Jan 18, 2006 11:19 AM
