TPS Problem
Old Mar 26, 2007 | 01:12 PM
copperhead
Default TPS Problem
Hi everyone,
I have a 2000 Honda Accord LX (134,000 miles), with the 2.3L 4cyl. The CEL came on and a friend pulled the code for me. It read as; P0122 TPS Pedal Position Sensor A, Circut low imput. It looks like the TPS is rivited to the Throttle Body, and I've read that with some of these the whole TB needs to be replaced when they go bad. Is this true?
If so, what are the options for TB's.
Thanks,
Eric
Old Mar 26, 2007 | 02:36 PM
Default RE: TPS Problem
TPS was not a replaceable part on earlier models and probably still the same. A new or used throttle body is probably the only option for replacement.
I would carefully check the connectors and wiring. Check from ECM input connector to TPS connector for a good wire and connector. The fault could be due to heat or wire pinching/cutting.
I've found that a liberal dose of WD40 or similar contact cleaner can have wonderful restorative ability on some type of electrical faults. It's cheap and worth a try. You need to get some inside the TPS housing which is normally sealed.
Old Mar 26, 2007 | 04:30 PM
smaglik's Avatar
Hahaha. I was thinking this was a problem with the TPS reports....
Old Mar 26, 2007 | 07:27 PM
sir_nasty's Avatar
And I was beaten to it.... as soon as I saw TPS Problem all I could think of was "why didn't you put the cover page on?" that's funny....
Old Mar 26, 2007 | 08:07 PM
copperhead
ORIGINAL: TexasHonda
I would carefully check the connectors and wiring. Check from ECM input connector to TPS connector for a good wire and connector. The fault could be due to heat or wire pinching/cutting.... <snip>...
Thanks,
I'll give that a try try before going for a new one.
ummm....yeah, I'm gonna have to ask you to come in to work Saturday. : )
Old Mar 26, 2007 | 09:47 PM
smaglik's Avatar
I CAN'T BELIEVE YOU ****** LUMBURG!
trouble
Aug 21, 2012 07:46 PM
live2rice
Jun 26, 2008 05:25 PM
Tai_Boi
Mar 29, 2008 01:08 AM
marbro
Feb 14, 2006 04:48 AM
marbro
Feb 6, 2006 09:28 PM
