Traction control and ABS lamps lit???
Old Dec 30, 2020 | 05:39 PM
wml52's Avatar
Default Traction control and ABS lamps lit???
A few days ago both the traction control and ABS warning lamps lit my 2011 Accord, obviously now both are not functioning. I would appreciate any help with what might be the cause and what I should check.
Thanks to all.
Old Dec 30, 2020 | 06:44 PM
A generic obd2 scanner may be able to read abs codes if you have one. If you don't have one, stop by a parts store and have them scan for codes, then post the code numbers on here.
Old Dec 30, 2020 | 09:19 PM
Seanjordan20's Avatar
List the codes. Do you have a spare on the car? Are you tires filled correctly? May have a bad ABS sensor. Codes will help out narrowing down the problem.
Old Jan 3, 2021 | 06:52 PM
wml52's Avatar
Still trying to find a place that can scan the ABS codes, everywhere I've been can only read basic OBDII codes.
wml52's Avatar
Old Jan 3, 2021 | 07:27 PM
You can get a daily cheap one off Amazon. If you keep having trouble finding a place. I would thing basic OBD2 reader can read them they just can't clear them. At least the ones I've seen.
SixtyMac
Dec 25, 2012 03:15 PM
Antarctica
Oct 30, 2008 08:16 AM
mark1975
Dec 4, 2007 07:05 PM
venks
Jun 23, 2007 08:39 PM
Yangster
Aug 31, 2006 02:17 AM
