Tranny Replacement and CV joint issue
Old Apr 15, 2008 | 09:46 PM
eric123's Avatar
Default Tranny Replacement and CV joint issue
Well I'm putting a new tranny in my accord. I have gotten the old one out along with the clutch. My problem is the bolts for the pressure plate are 12 point. Now I was able to get a 10mm wrench on my sanding it thinner so it would fit and not hit the prssure plate but it was kind of a crude method and didn't work the best. My issue is will a 12 point socket fit on or should I not waste my time buying it. How is it normally done?
EDIT: I'm also having an issue with the CV joint. When I was removing the driver's side CV joint which is brand new I guess I must have popped the bearing out. How do I get them to sit back in, I tried to push them back in but can't whats the trick.
Old Apr 16, 2008 | 11:36 AM
BlkCurrantKord's Avatar
Default RE: Tranny Replacement
If it requires a 12 point, use a 12 point. They're only a few bucks.
Old Apr 16, 2008 | 09:36 PM
eric123's Avatar
Yes, I get that but my problem is that it is hard to get anything on it because of the tight fit between it and the pressure plate. I was wondering what anyone else uses to get it off. If there is some special socket or wrench I just don't know about, or what.
Also I edited my post, I'm having an issue with the CV joint as well.
Old Apr 17, 2008 | 01:15 PM
eric123's Avatar
I was able to find a 10 mm 12 point thin wall socket, so now I'm just having my cv joint issue
dsnt flt
Mar 23, 2010 10:33 AM
partschanga
Jan 28, 2010 06:34 PM
husky100
Oct 11, 2008 09:00 PM
willyg
Mar 2, 2007 09:06 AM
di2iftwood
Jan 3, 2006 05:00 PM
