Trans-axle leaking oil BAD!
Old Aug 8, 2010 | 02:22 PM
ruuruu's Avatar
Default Trans-axle leaking oil BAD!
Was just going to change oil on my daughter 2000 accord. I jumped in it to take it for a little ride to warm it up it made a "clunk" when I put it into reverse which concerned me. Took it for a drive and could feel / hear a slight roughness to the drive......
Put it on ramps, crawled underneath and noticed the transmission and bottom of car wet with red fluid. DARN!!!!!
Grabbed the axle shaft on the drivers side and it will move back and forth a good 1/4 inch. The other side does too but not as bad.
Anyone have an idea what the diagnosis will be????? Its a sure thing that the bearings / seals are out for the shafts......?
Do you think the tranny will still be OK? Any ideas on repair costs?????
Thanks in adavance
WV from North Dakota
Old Aug 8, 2010 | 05:49 PM
kris_loehr's Avatar
Is the driver’s side axle seated in the trans and if it isn't have you had work done on your vehicle lately.
Old Aug 8, 2010 | 06:33 PM
hondadude's Avatar
this is a real common problem on the 98-02 accords.
Differential bearings are tapered roller bearings.
The worst thing about it; all the metal flakes go through out the entire trans.
Here's what they look like when ya open up the trans;
Old Aug 8, 2010 | 08:14 PM
ruuruu's Avatar
Default So looks like a complete tranny???
Sooooooo does this mean that it is usually a complete tranny replacement??????? From the little research I've done that could mean up to $3500. Geeeez the car is hardly worth that.............Maybe get her a different car and see if I can take on this job myself ----- or sell it for parts.
giulio76
Dec 29, 2012 11:16 AM
crispin
Apr 22, 2012 10:00 AM
bruce42106
Dec 5, 2008 08:10 PM
sparlanc
Nov 22, 2008 08:36 AM
nixalot
Jan 25, 2007 02:02 PM
