trans fluid leak
Old Mar 4, 2012 | 08:58 AM
topcat's Avatar
Default trans fluid leak
Hello honda family got a leak transmission fluid leak coming from what looks like a pressure switch on the passenger side under the engine block part can be easily reached by removing the black plasitic covers under the car this part is also located next to a small drain plug took car to a mech he tried to tighten it but still leaks car runs and drive good no shifting problems need to know which switch this is because was going to have mech change it he seemed to not no which it was and to diy do you have to drain all the trans fluid. You guys help is very appreciated CAR IS A 2000 ACCORD EX
Old Mar 4, 2012 | 10:28 AM
Is this a 4 cyl?
Old Mar 4, 2012 | 12:43 PM
topcat's Avatar
yes 4 cyl
Old Mar 4, 2012 | 01:07 PM
crispin's Avatar
a picture is worth a 1000 words, 2 pictures are even better.
Old Mar 4, 2012 | 02:10 PM
Poorman's picture is for automatic trans. Is that what you have?
Old Mar 5, 2012 | 05:33 PM
Thanks Jim, should have ask that as well
Old Mar 6, 2012 | 05:46 PM
topcat's Avatar
well guys i did some more reserch and found out it is the 4th gear pressure switch that has a leak easy fix remove the battery and tray and wow there it sits no jacking car up or removing all the splash gaurds under the car to get to part 80 bucks with washer thx for you guys help hope this fx the tran leak
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
poolman
Apr 11, 2010 10:16 AM
2.2ex965spd
Jun 5, 2006 11:14 AM
