Transmission
Old 01-04-2012, 11:02 PM
The 98-02 had major transmission problems due to a design problem. From what I read, one of the bearings would fall apart and clog up the fluid lines causing the transmission to fail.
The 03-07 accords seem to have pretty reliable automatic transmissions. Honda had to correct the problem. Not sure what they did.
Old 01-04-2012, 11:19 PM
Wow, that's good to hear. Thanks PAHonda!
Old 01-05-2012, 08:39 AM
Honda has improved there Transmissions. In the mid 90's to early 2000's they have bad Torque Convertors which will clog the trans filter and give a delayed engagement or loss of engagement (usually coming to a stop) and the bearing problem is a Thrust Brg. In the 2nd/4th drum assy. You will have to replace/update the Drum assy. with the overhaul of the Transmission and Yes flush the system.
Old 01-05-2012, 06:14 PM
Originally Posted by accordhybridowner
Why do you think so? My car is only one generation newer than his.
But thanks for the answer, I just wanted to know what would happen in such case, even if it will NEVER happen to me
I should have added...."With proper care and proper fluid"....I'm going to edit my post and add this.
MessAround
08-13-2011 09:45 AM
Quick Reply: Transmission
