transmission additive
Old Jun 20, 2008 | 09:16 PM
Trickster's Avatar
Default transmission additive
I have been reading that its good to add an additive to the ATF if its shifting harshly.
I have a 92 Accord EXR thats not that bad, but have been thinking of adding this stuff, as I am reading it everywhere including consumer reviews.
Problem is I am seeing more than just one type.
They say to add Lubegard AT conditioner.
I have found this: http://www.midwayautosupply.com/c-14...-products.aspx
Can anyone tell me which Lubegard I should be getting?
Thanks
Old Jun 20, 2008 | 10:41 PM
Default RE: transmission additive
If the tranny is shifting harshly, you should change the tranny fluid using honda ATF.
Drain, refill, drive for a day. Do a total of three drains/refill to exchange a majority of the fluid. The reason you do this is that you only drain about 1/3 of the fluid from the tranny. Examine the fluid when you drain it. It should be clear, no burnt smell, and no metal shavings. Remove any metal shavings stuck to the magnetic drain plug.
Old Jun 21, 2008 | 11:11 AM
GM SYnchromesh is for MANUAL trannys. It would be bad for a Honda automatic.
Old Jun 21, 2008 | 11:31 AM
Agree w/ using only Honda ATF and couple of changes.
If any work has been done on throttle body or transmission, the throttle control cable may need adjusting. Throttle plate and throttle control lever on transmission should begin to move at same time.
Misadjustment can cause harsh shifts. Adjustment can be used to tailor the shift feel. Download 91 Accord shop manual from hondahookup.com per Online Manuals link for details.
MessAround
Aug 13, 2011 09:45 AM
ryandavis33
Feb 27, 2011 03:55 PM
thunder_x
May 3, 2007 04:14 AM
thunder_x
May 2, 2007 08:39 PM
