Transmission Codes 0700 and 1705
Old Jul 9, 2009 | 08:28 AM
flashbang
Default Transmission Codes 0700 and 1705
Hi all, new member here. My CEL is on and popping codes 0700 and 1705. The transmission was replaced at 90,000 miles. Is this a sensor issue or is it a mechanical issue?
Transmission seems to be fine, no burnt fluid or leaks...just these codes which appeared after my main relay went bad. I replaced the main relay and reset the codes, but they did come back.
Any help would be appreciated.
1999 Honda Accord EX 2Dr, Auto Trans, 103,000 miles
Old Jul 9, 2009 | 12:10 PM
P0700 is general transmission fault and occurs whenever any trans code is set. P1705 is Transmission Range Switch short. A short in the automatic gear selections switch or wiring. You may not see the auto trans gear selection in the instrument panel. It could be a wiring fault, but switch fault is more likely.
Old Jul 11, 2009 | 04:15 AM
flashbang
Default Thank you for the info
Thank you, I will look into that. Although I do see the gear selections on the dash display.
rahulmunjal
Feb 27, 2012 12:10 PM
LuckyHonda
Sep 17, 2010 05:30 PM
Andy428
Nov 9, 2007 09:27 AM
rafo_555
Dec 7, 2006 07:56 PM
larrysnach
Mar 11, 2006 10:48 PM
