Transmission delay in shifting
Old Sep 28, 2014 | 10:37 PM
Elguyo's Avatar
Default Transmission delay in shifting
Transmission delay in each gear. Revs up higher than normal before shifting. Tran Fluid Ok. Could this be TCU? If so what code would be displayed. 92 Accord DX Auto.
Old Sep 29, 2014 | 07:18 AM
Is D4 light blinking? If yes, see DIY forum for instructions on determining code. Even if light is not blinking some code/s may be stored.
Flaring at shift is a sign of aging that generally can't be fixed w/o trans overhaul. However it usually affects 1-2 shift first.
Are you using Honda ATF? If not, suggest several drain/refill/run cycles to replace w/ Honda ATF.
Check the AT throttle control cable. Throttle control lever should begin to move at same time as engine idle increases. Adjust locknuts to change throttle control cable setting.
Old Sep 29, 2014 | 02:44 PM
Elguyo's Avatar
Thanks.
Rilex
Oct 30, 2013 02:20 PM
PizzaFoundry
Nov 6, 2009 07:18 AM
alsalp
Jan 5, 2009 11:07 AM
somerustspots
Oct 22, 2008 06:09 PM
miki
Aug 11, 2006 03:59 AM
