Transmission Drain Bolt 2006 4 cyl
Old Jul 2, 2008 | 10:57 AM
jackkpts's Avatar
Default Transmission Drain Bolt 2006 4 cyl
Where is this drain bolt?? I thought I remember a pic on this site, but get no hits when searching even on "transmission". Thanks....Jack
[align=left] [/align]
Old Jul 2, 2008 | 01:33 PM
nafango2's Avatar
Default RE: Transmission Drain Bolt 2006 4 cyl
if its anything like my much older accord, its on the side of the transmission by the wheel. transmission drain bolts typically are round on the outside (as opposed to a hex shape) and have a square plug that you just stick a socket wrench into.
Old Jul 2, 2008 | 03:07 PM
falkore24's Avatar
It'll also be on the lowest point on the transmission. They can be really tight to crack free. I warpped a cheap ratchet on mine. Make sure that you have a new crush washer for when you are done.
Old Jul 4, 2008 | 09:57 AM
jackkpts's Avatar
What is the torque setting for this bolt?
Old Jul 5, 2008 | 04:57 PM
2003 V6
I have a 2003 V6. Yours also not differ form 2003.
You can easily find hex shape (engraving). the size maybe about 8 mm.
If you really want replace purely^^, you need drain 3 times (including old fluid).
I wish this description will help.
anupm12
Sep 15, 2014 11:21 AM
Fredcheesemonkey
Aug 4, 2013 02:26 PM
jcg2000
May 18, 2009 09:09 AM
jackkpts
Jul 8, 2008 10:14 AM
jon02accord
Mar 26, 2008 10:54 AM
