oil drain plug bolt size
Old Aug 4, 2013 | 12:30 PM
Fredcheesemonkey's Avatar
Default oil drain plug bolt size
so the other day while i was working on my car one of the things i was doing was changing the oil. when i tried to get the drain bolt off with my 3/8 17mm ratchet it wouldn't budge. i tried different angles and while doing that it slipped twice. so i stopped and found my 17mm flare nut crow foot and tried that then that slipped. thats when i realized i stripped the bolt. i need to know the bolt size so i can get a new one. im trying to avoid getting a honda part and spending a bunch of money but if it come to that i will. also do you guys know any tricks that i could use to get it off? i do have a damaged bolt remover kit.
Old Aug 4, 2013 | 12:54 PM
The oil drain bolt should be M14 x 1.5 x 10.
Metric thread diameter x thread pitch x thread length
Wrench/socket hex size would be 17mm.
Old Aug 4, 2013 | 02:05 PM
Suggest a good set of vise grips and tapping firmly on wrench w/ hammer to break bolt loose.
Someone overtightened originally, or you wouldn't have had the difficulty w/ 3/8" ratchet. I usually use a 1/2" ratchet w/ 1/2x3/8 reducer to socket to gain a little more leverage, or use a breaker bar.
Old Aug 4, 2013 | 02:26 PM
thank you very much. ill try this in a bit. xgames for now!
alltime3rdwheel
Dec 31, 2012 10:46 AM
jcg2000
May 18, 2009 09:09 AM
jdwilson4
Nov 13, 2008 09:54 AM
jon02accord
Mar 26, 2008 10:54 AM
desi01
Jun 24, 2006 05:49 AM
