Transmission Fluid
Old Jun 1, 2011 | 05:39 PM
deerdawg's Avatar
Default Transmission Fluid
Is there a transmission fluid that can be used from an auto parts store or do you have to use the DW-1 fluid from the stealership.
Thanks
Old Jun 1, 2011 | 09:28 PM
DEBATE started....Anyway I don't mind giving my two cents.
Two fluids on a Honda I NEVER want to mess with. IF the manual calls for Honda trans fluid (Z1, beging replaced by DW1), use it...I've seen Honda trans fluid at CARQUEST. Second, the power steering fluid, only use Honda APPROVED fluid, not the universal stuff, must say approved for Honda/Acura.....as far into this as I want to go.
Old Jun 1, 2011 | 10:50 PM
deserthonda's Avatar
do not even waste a second thinking about it ,,,, Honda tranny fluid used to be atf-z1 now it is atf dw1, i know that it is not cheap but all you need is 3 qts and you replace it every 30k miles ,,, trust me,, well worth the money
Old Jun 1, 2011 | 11:06 PM
And that is the answer above that you need to go by..Hey Desert
Old Jun 2, 2011 | 04:24 PM
deerdawg's Avatar
Thanks everyone. DW1 it is.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
MessAround
Aug 13, 2011 09:45 AM
emaxxman
Feb 27, 2006 10:44 PM
