Transmission fluid change question
Old Dec 18, 2010 | 09:11 PM
barticus520's Avatar
Default Transmission fluid change question
when you remove the transmission pan to change the fluid do you have to change the gasket or can you reuse it? if not then where could I get it quickly or do i have to go to a dealership?
Old Dec 18, 2010 | 09:51 PM
monsterb1's Avatar
Why would you remove the pan for trans change/flush?
Old Dec 18, 2010 | 09:56 PM
there is no drain plug as far as i can remember( if im wrong tell me i havent been under the car since early november when i changed the oil.)
Old Dec 18, 2010 | 11:58 PM
well after about an hour of searchin the internet i found another forum talking about this issue. http://www.driveaccord.net/forums/sh...?t=3047&page=2 they show pictures and tell you step by step how to change the fluid. LOL luckily i found this before i went in the morning to remove the whole tranny pan.
Old Dec 19, 2010 | 11:41 AM
So I did the partial tranny fluid change with 3 qaurts. Really easy, easier than changin the oil cept that you need a 12" extension to remove the ATF filler cap hidden under the fuse box. Also loved the magnetic drain plug. I saw a little bit of metal shavings on the plug but not much. Anyways the car shifts perfect now.
Old Dec 19, 2010 | 09:30 PM
Yeah, unlike most other auto-trans, Honda doesn't have a pan. Easy to change the ATF.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
logannz
Mar 30, 2013 05:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
