Transmission fluid question
Old Dec 9, 2010 | 11:29 AM
barticus520's Avatar
Default Transmission fluid question
Quick question, what type of transmission fluid does an 05 accord v6 auto use? i read something about a special honda ATF but searched autozone and only see mercon, dexron, and synthetics.
also where could i buy it
Old Dec 9, 2010 | 01:27 PM
Honda ATF from a Honda dealer.
Dexron for emergencies, but then you'll want to do multiple drain/fills to get rid of the Dexron. That uses even more fluid in the long run.
Old Dec 9, 2010 | 04:31 PM
djalmab's Avatar
Default Honda has extra additives
Jim is right.
There was a recent discussion on this on this forum.. Honda has special additives on top of those oils.. Go always with the honda one.
Old Dec 9, 2010 | 06:59 PM
Just to add. I recently saw genuine Honda Z1 ATF at a local CARQUEST store, I think for around $8 qt. I actually checked the upc code on the back of the bottle and compared it to some I already had at home and it matched....just putting that out there as another source, check the dealer price and compare.
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
MessAround
Aug 13, 2011 09:45 AM
barticus520
Dec 22, 2010 11:11 PM
barticus520
Dec 19, 2010 09:30 PM
