transmission leak
Old Mar 18, 2007 | 06:51 PM
bmxfelon420's Avatar
Default transmission leak
I was out fiddling with the car a bit earlier, and i topped off the coolant, confirmed that the oil is indeed gross looking and needs changed, and that i have what appears to be a transmission leak. I say this because if it was oil it'd be black, like it was when i checked it [X(]. Where is the oil dipstick? I heard that it was under the battery, but i wasnt sure.
Hopefully i can jack it up soon to see where it's leaking at, and probably get it fixed when im getting the oil changed hopefully.
Old Mar 18, 2007 | 08:39 PM
hondadude's Avatar
Default RE: transmission leak
What COLOR is the car?
Important info is missing from this post.
Old Mar 18, 2007 | 08:42 PM
deserthonda's Avatar
Old Mar 19, 2007 | 12:16 AM
i actually did put year and model in my signature, but for some reason my signature isnt showing up. Im going to check if there isnt some sort of box i have to check, usually on most forums it is enabled by default.
anyways if it doesnt start working, its a 91 accord LX AT.
Old Mar 19, 2007 | 12:20 AM
i fixed it, there is a "always attach signature to posts" box that wasnt checked by default, i checked it now. Thanks for pointing that out, i wasnt sure if it was an issue where i couldnt see my own signature, or nobody could.
Old Mar 19, 2007 | 12:04 PM
hondadude's Avatar
The Trans dipstick will be at the front of the trans where the lower radiator hose goes down. Check it with the engine off.
Johnene
Aug 24, 2010 06:59 AM
v-tec23
Aug 14, 2010 08:43 AM
EBK142
Jul 20, 2009 09:10 AM
xaznxeclipsex
Sep 28, 2007 02:05 PM
jbruning
Jul 17, 2006 03:39 AM
