transmission problems
Old Jul 13, 2012 | 10:24 AM
windstorm71's Avatar
Question transmission problems
hello all. first time here and from what i have seen looks pretty informative.
tried to find something similar to my problem, but was taking to long to search.
i have a 1992 Honda Accord EX with 292,000 miles on it. I bought it used and it had 220k then. for about a month now i have noticed my automatic transmission shifts real hard. i pretty much baby it when i take off because if i dont then when it shifts from 1st to 2nd it pretty much makes the car shutter and makes a clunking sound(dont know how else to describe it lol).
Someone suggestion that i needed to have it serviced. change filter and screen, gasket ect. so my question is, should i service it?? do i have to take it to a shop? what is involved when doing this? do i have to take apart the whole car? just drop trany? please any insight would be greatly appreciated.
Thank you!
Old Jul 13, 2012 | 01:15 PM
UhOh's Avatar
welcome to forum. active thread here with similar topic
https://www.hondaaccordforum.com/for...-normal-48696/
I'd try drain & fill fluid first since it's so easy and not much $$.
Probably x2 since sounds like your AT hasn't been serviced in a while,
but others here are more experienced at AT's.
Old Jul 14, 2012 | 09:44 AM
After that, check the throttle control cable going the the trans for proper movement and adjustment.
Also check the motor/trans mounts.
Old Jul 14, 2012 | 09:48 AM
Check for transmission codes (see DiY forum same for trans as engine codes). Some trans codes don't cause D4 or S light to flash.
dzimmerman1977
Nov 15, 2006 07:10 PM
YeuEmMaiMai
Sep 4, 2006 10:27 PM
KimberlyC
Apr 16, 2006 11:51 AM
monroe
Oct 24, 2005 10:22 AM
darkstar05
Apr 13, 2005 10:13 PM
