transmission or something issue...
Old Sep 21, 2012 | 07:13 PM
jfreakofkorn's Avatar
Exclamation 99 Accord...transmission or something issue...
I hope that this is the right section for this thread.... but here we go....
I have a 99 accord EX with a auto ( a BAXA trans )
The problem that I am having is that, when Im going down the road and before it hits 2nd, the rpms would jump.
Mid way thru 2nd gear it would do it again before 3rd....
With 3rd, 4th, etc doing the same.
Whats done with the car is:
Replaced two solenoid(s)
( one under the battery tray and the one by the trans line in front, these are the double ones )
Checked the other two
( which 5they work and no problem there and tested )
Cleaned all the screens/filters on them
( even the new ones )
Rebuilt the transmission
( explains itself )
Replaced throttle body
( which was giving the code for it with the computer )
Fluid is at normal level....
What else can give it this problem.... Im about fid up with this car thinking that it didnt need work....
And the wifes coming back in Like 13 days ( which its HER car )
Old Sep 22, 2012 | 05:32 PM
Any opinions/thoughts ......
Old Sep 23, 2012 | 06:17 AM
Are you using Honda trans fluid?
Are there any stored/pending codes?
Old Sep 23, 2012 | 09:09 PM
Silver6gen's Avatar
replace trans fluid with HONDAs fluid. also make sure it is NOT overfilled even slightly.
if that doesnt change n e thing then let us know
Old Sep 26, 2012 | 06:08 PM
Changed the fluid and at $8 per bottle didnt do the trick.....
ALso replaced the ICA valve on it also
Same problem....
Old Sep 26, 2012 | 06:11 PM
No codes, had my friend that I do alot of R&R ( Remove and Replace ) hooked one up and had no reading to it.....
abhijitgp
Apr 3, 2011 10:30 AM
kellysa111
Mar 26, 2010 09:47 AM
Mar 19, 2006 03:38 PM
Dec 27, 2004 02:24 AM
