Transmission Whine
Old Feb 7, 2008 | 02:33 PM
4alkings
Default Transmission Whine
Just bought a used 2003 Accord Ex-V6 and have noticed that the transmission makes a high pitch whine noise that is heard in the interior around the gear shift ****. Anyone else had that problem? Any solutions?
Old Feb 7, 2008 | 02:53 PM
sir_nasty's Avatar
Default RE: Transmission Whine
When does it happen? How can you get it to stop? Does it change pitch or sound at different times? How's the tranny fluid level/color?
Old Feb 8, 2008 | 06:54 AM
4alkings
Noise is most noticable under acceleration. Heavy acceleration seems to make it louder. Have not yet checked trans fluid level or color, but will do so and post results.
Old Feb 9, 2008 | 07:04 AM
4alkings
Checked fluid level and it is fine. Trans fluid color is a deep red. Appears fine to me.
Old Feb 9, 2008 | 08:38 PM
mpanelli's Avatar
Deep Red? Is it more like a brick or burnt red or a Bright red? It should be bright red. But the color of the fluid will not have anything to do with the noise as long as the level is correct. Are you sure you are hearing transmission noise and not a different noise?
Old Feb 10, 2008 | 10:41 AM
HondatechAV6's Avatar
sounds like the tranny is dying.
new fluid is pink. ok fluid is red. aging fluid is dark red/brown, dead fluid is brown..
jeffjohnvol
Jun 30, 2010 09:54 AM
Kai Winters
Sep 28, 2007 02:01 PM
thug@$$n1gga
Aug 16, 2007 10:27 PM
ckebottle
Sep 23, 2006 09:35 PM
Jon B
Jun 18, 2006 04:36 AM
