Transmission won't shift on it's own
Old Apr 28, 2010 | 02:06 PM
smoke6273's Avatar
Default Transmission won't shift on it's own
1992 Accord wagon LX with 169k miles D4 light won't light up on dash trans will shift manually from 2nd to D3 but not 1st or D4. Car had been sitting up for like 2yrs prior to driving trans fluid was totally black and idle sensor seems to be faulty car idles up and down! Can the shift selonid be changed and solve trans problem? Please help
Old Apr 28, 2010 | 04:17 PM
You posted this onto the end of an unrelated thread, so I moved it to it's own separate thread...
You can change the solenoids, but whether that will fix the problem is another question. I'm no auto-trans guru, so I hope someone else chimes in.
Old Apr 28, 2010 | 06:01 PM
EXV6NIGHTHAWK's Avatar
This link has a wealth of information on 4th gen (90-93) Accords, including transmission troubleshooting. Hope it helps find the problem. Good luck
http://www.techautorepairs.com/transmission.html
rydnlow1120
11
Nov 11, 2015 05:29 PM
struppi
Feb 11, 2013 04:12 PM
Amtrak288
Aug 31, 2011 08:18 PM
thunder_x
Oct 24, 2007 10:26 AM
