Turn key and nothing happens
Old Feb 8, 2011 | 06:15 PM
Gimmeyarn's Avatar
Default Turn key and nothing happens
Today when I got in my accord I out the key in the ignition and nothing happen, no lights, no dash, no turn over. I tok the key out and waited a few minutes and it started back up no problem. I figured it was just a fluke so I let it go until it happened again later in the afternoon. This time I tried many times before the care finally lit up and turned over. Any thoughts?
Old Feb 8, 2011 | 06:22 PM
Can we at least know the year of the car? The more information the better.
Without that...check, clean and tighten all of the battery connections.
Old Feb 8, 2011 | 06:46 PM
Gimmeyarn's Avatar
Sorry. 2004 Accord Lx two door. Less than 50,000 miles. Never had a problem until today other than battery replacement in the fall. checked the battery when it happened this morning.
Old Feb 8, 2011 | 08:38 PM
Ok, sorry for sounding blunt...I'm still with double checking the connections. Can you give more details to "checked the battery when it happened this morning". If the battery is good, voltage at the starter (big cable and the small one) are good then I'd go with the starter. So, check the voltage on those two...if you have power to the starter (both cables) and nothing happens, pull it, have it tested and replace if bad.
Old Feb 9, 2011 | 01:09 AM
Youll also want to look for leaking fuel injectors, Faulty fuel pump where the fuel is not getting up to the fuel rail fast enuff, Fuel pump relay not working..I could go on and on..You need to get it started and then taken and have those thing tested.
Old Feb 9, 2011 | 06:59 AM
Gimmeyarn's Avatar
No need for appologies. Goingto check some things this morning.
csh217
Jun 17, 2014 05:53 PM
osomex
Feb 1, 2012 07:30 AM
turnbacknow
Nov 17, 2010 12:20 PM
Turkey
Jul 18, 2006 04:39 PM
