Turn signal
Old Oct 28, 2009 | 08:53 AM
ezekielguy86's Avatar
Default Turn signal
I bought some new turn signal bulbs for the front of my car. I bought some led one they are 1157 and I got one the other has yet to come in. I put it in to see what it looks like and my indicator goes real fast on the side with the new bulb why is that.
Old Oct 28, 2009 | 09:40 AM
00AccordLX5spd's Avatar
Registered User
Is the rear bulb on the same side still functioning?
Old Oct 28, 2009 | 09:57 AM
It flashes fast because the LED draws far fewer watts than a bulb. Your flasher is designed to work with bulbs, so the LED looks like a burned-out bulb. Some LEDs can be equipped with a resistor to draw a comparable wattage like a bulb, so you might have to do that.
Old Oct 28, 2009 | 12:34 PM
rear bulb works just flashes fast also. So I basicly can't use this bulbs without them flashing super fast. Can you recommend some bulbs that would be bright white.
Old Oct 29, 2009 | 12:45 PM
hondadude's Avatar
The flasher circuit is a R-C setup, the different resistance causes the capacitor to load/unload faster.
I think the answer is to put a 330 [??] ohm resistor on the ground side of the led bulb
HAcc407
Mar 7, 2006 09:43 AM
zelseman
Jan 8, 2006 04:19 AM
aghigig
Nov 20, 2005 03:04 AM
jcvlz
Aug 24, 2005 11:34 AM
mega502
Mar 19, 2005 12:30 PM
