Turn signals/flasher not working
Old May 27, 2019 | 01:36 PM
Bigdawg51's Avatar
Default Turn signals/flasher not working
Ok so I got a 99 Honda Accord 2.3. This problem is very weird as the turn signals and the 4 way will work for a bit then go out then come back on. Now if you wiggle the flasher relay around you can get it to work for a bit then they quit and come back on... someone have any advice?
Old May 27, 2019 | 03:57 PM
I'd pull the flasher relay and check if the relay pins have any corrosion. You may want to put a slight twist in the pins to ensure good contact.
If that fails, then I'd probably replace the flasher/turn-signal relay.
Old May 27, 2019 | 04:19 PM
Bigdawg51's Avatar
I did both of them still the same thing is happening
Old Jun 15, 2019 | 11:13 PM
Bigdawg51's Avatar
Anyone have any ideas????
Old Jun 25, 2019 | 03:44 PM
Since you get a response by wiggling the relay, it must be somewhere close. So what about flaky wiring behind the relay socket. If you can get to the wiring, look for corrosion between the crimped connector & the wire itself. Or something of that nature.
PeterFlorida
Feb 26, 2013 09:09 AM
dustin3
Aug 17, 2011 04:52 PM
twisted95accord
Sep 4, 2010 09:10 PM
wsbowen03
Apr 30, 2009 02:46 PM
kennilope
Jan 26, 2007 03:14 PM
