ULEV swap on 95 lx!!!!! PLEASE HELP!!!
Old Oct 18, 2009 | 10:30 AM
Honda_JD
Default ULEV swap on 95 lx!!!!! PLEASE HELP!!!
hi, i recently bought a 95 accord lx with a bad engine, i want to replace the engine so i bought a 98 ulev vtec engine, i was wondering what else do i need to do the swap besides the ecu? the engine already comes with all the wiring, also the ulev came off a auto and my car is a 5spd.... anyone knows what i need for the swap?
Old Oct 18, 2009 | 05:39 PM
Honda_JD
anybody around with accord expertise know anything??? no one out there?
Old Oct 18, 2009 | 06:38 PM
Honda_JD
wow this forum sucks
Old Oct 19, 2009 | 02:58 AM
I'm sure that the swap can be done, but it may be a PIA.
Here are some things you will have to consider when when doing that kind of swap.
Will your 95 transmission bolt up to the 98 engine. Are the mounts in the same location to bolt the engine to the frame. Will the 95 axles and steering rack work? Looking for identical aftermarket part numbers for the 95 vs the 98 will help determine if these are interchangeable.
You will probably need a catalytic converter from a 96/97 or 98-02, because your 95 only has one o2 sensor, so your 98 ECU will always have your check engine light on.
Old Oct 19, 2009 | 10:56 AM
When I had a 98 (& I had the Helm shop manual for it) I remember the ULEV had a MUCH different wiring harness. I would expect that you'll need more than just the OBD-2 wiring harnesses, but they have to be specific to the ULEV (California) engine.
Old Oct 20, 2009 | 04:06 PM
Honda_JD
what if i convert the engine to a obd1 ???
Old Oct 20, 2009 | 05:12 PM
I don't know the differences between the ULEV and the normal engine, so it may or may not be simple to do. Some of the sensors may be different and could be in different locations.
I also don't know what ECU you would be able to use. It may have to be an OBD2 ECU from a non-ULEV vehicle. I'm not sure how well a stock 95 OBD1 ECU will be able to handle the 98 engine.
There are a lot of things to consider when swapping between different generations of accords, so most people suggest replacing an engine within the same generation accord. Like replacing the 95 engine with a 94/95 engine. You will have much less of a headache when doing this.
Old Oct 20, 2009 | 05:25 PM
Once upon a time someone said the ULEV engine has a 32-bit ECU instead of the 16-bit one for the other 2 engines. All I remember is that there were tons of differences in the wiring harness. Wide-band O2 sensor for the ULEV, and it was at a different set of pins vs. the non-ULEV ECU. O2 sensor heaters were powered out of a different fuse, all kinds of things that should have been un-related.
Old Oct 21, 2009 | 05:28 PM
Honda_JD
so is probably easier to put a 95 ex vtec engine to a 95 lx?
Old Oct 21, 2009 | 05:46 PM
I think that would be easier, because the mounts, transmission, axles, etc will bolt right up.
You will either need to modify the wire harness (or get one from a 95 EX) and the EX ECU.
