ULEV swap on 95 lx!!!!! PLEASE HELP!!!
Old Oct 22, 2009 | 07:05 AM
Modifying your wiring harness for a 95 EX engine would be much much easier vs. a ULEV engine. It's possible that the car's harness is the same and you'll only need to have the engine harness from the EX engine.
Old Oct 22, 2009 | 02:35 PM
Honda_JD
so the ex computer would fit right up,? so wire, plug, and play?
Old Oct 22, 2009 | 02:51 PM
Yeah, whenever you keep the same year, you have less differences. People talk about "5th-gen" or "6th-gen" all the time, but really Honda makes small wiring changes all the time.
Old Oct 22, 2009 | 04:23 PM
finch13's Avatar
Wow, that was a horrible call on your part blindly picking out a Honda motor to swap in...
Even the 98-02 guys don't swap those ULEV engines in because they are such a pain to work around the 32-bit ECU and wideband O2 sensor.
There's a lot of wiring connectors that need to be re-pinned to get it to work and in the end it's not worth the time or money. I don't know of any mechanic who'd be willing to take on the work or any owner that would be willing to pay for that many labor hours.
Assuming your LX has the F22B2 in it (non-VTEC), the F22B1 (VTEC) is a fairly simple swap. You will need the EX ECU and the VTEC solenoid needs to be wired and I believe the distributor needs to be rewired.
Old Oct 22, 2009 | 04:45 PM
Honda_JD
fok it, i just went and returned the ulev and picked up the regular lx engine,? is gonna be easier and painless
Old Oct 22, 2009 | 04:52 PM
finch13's Avatar
Well I'm glad you returned it. I wish you would've asked us first before picking up the engine!
It should be a straight swap.
Old Oct 24, 2009 | 08:12 AM
  #17
Honda_JD
but im still planning for later on to put a vtec head,,,, i heard is possible, lx bottom with the ex head, i hear u can connect the vtec to a switch so i dont need the ecu,,, have u heard something like that before???
99accordf23a5
May 6, 2014 12:51 AM
jhillblessed
May 10, 2010 11:58 AM
jhillblessed
May 10, 2010 09:55 AM
chesswiz
Apr 6, 2007 03:08 PM
01Accord
Feb 6, 2007 11:37 AM
