Under hood insulation-good or bad??
Old Jun 24, 2011 | 07:11 PM
dunkinidaho's Avatar
Default Under hood insulation-good or bad??
I've installed 3/4 in of foil backed foam insulation under my hood. The temp guage does not indicated over heating however when I pop the hood after a drive the engine seems very hot. Should the insulation be removed? I installed it in the first place to reduce noise but it wouldn't be worth frying the engine for.
Brian in Mich.
Old Jun 24, 2011 | 07:49 PM
What accord are we talking about here? Put that info in your signature, so we don't have to ask.
If the temp gauge is not going up, you should be ok.
I think that the EX accord had sound deadening pad to reduce noise (depending on the year). I am not sure if it acts as an insulator. That should depend on the material used.
My TSX has this feature as well.
Old Jun 25, 2011 | 05:05 PM
thanks, that's kinda what I thought. I wanted to run it by some others for opinions
Brian
88 Accord Hatchback
giulio76
Dec 29, 2012 11:16 AM
RobinsonRicer
Aug 1, 2012 03:34 PM
sacrider
Jul 30, 2011 05:24 PM
ad00a973
May 3, 2009 09:36 AM
