Vacuum Leak causing surging idle?
Old Mar 5, 2013 | 06:41 PM
  #21
So....is the idle better now?
Old Mar 6, 2013 | 09:15 AM
  #22
Brandon Saunders's Avatar
Default Yes!!
So the idle is a whole lot better. It stars up at like 1200 and will wind its way down to about 900 in park. And in drive it sits at 900 when i'm idling. If I hit the gas too much in Park or neutral it will do the surging idle but that's ok. I tightened the locking nuts near the spring and control arm. It's a bit tight so I'm going to loosen it up bit by bit. Thank you again.
Old Oct 4, 2021 | 06:35 AM
  #23
Sain1979's Avatar
Default Vacation leak
Originally Posted by Brandon Saunders
So I've been working on the surging idle for over a week and a half now reading all the forum posts etc...
So far I've:
Cleaned/Replaced IACV, FITV, Air boost valve, cleaned the TB, changed air filter, changed spark plugs, checked for vacuum leak, put techron fuel injection cleaner in, and put a new fuel filter in. So now I pulled the Vacuum Control Box off to check the MAP sensor and I can't really figure it out.
Oh and it only does the surging idle from 1500 to 1000 RPMS in Park and Neutral. No code is thrown. Any more ideas and I would be much appreciative! Thank you all for reading!
I'm having the same issue have you tried the egr valve or the tps sensor.. you said you replaced the IACV you check the map sensor .. the map sensor and IACV work hand in hand if o e is not working properly or try doing idle relearn that is has to be done for sure... If i give any more ideas . Do this first its call idle relearn look it up anytime you do work around throttle it has to be done.
Nancy
Nov 9, 2011 08:20 PM
Rokkandy
Sep 5, 2011 08:16 AM
v-tec23
Aug 14, 2010 08:43 AM
hercirock
Jun 1, 2007 02:45 PM
kwiggers
Mar 16, 2005 07:29 PM
